Activity Forums Boris FX Video Not in Sync with Audio using Boris XML Transfer?
  • Video Not in Sync with Audio using Boris XML Transfer?
    Posted by Gabi Bucataru on November 4, 2011 at 2:09 am
    Hello gents,
    I have an issue with audio syncing exporting a FCP 7 sequence via Boris transfer to After Effects CS5.
    The video clips have a delay of about 1.5 second. The strange thing is that in AE looks like the beginning of the video clips got shifter earlier for some reason.
    Here’s my procedure to export:
    From FCP 7:
    – I created a separate sequence containing a group of video and audio clips copied from the main movie sequence (in total about 4 seconds).
    – the sequence to be exported has the same settings as the main sequence from where the video/audio group was copied
    – Exported the sequence as XML version 5.
    Into AE CS 5:
    Import->FCP via Boris XML transfer.
    Anything I might be doing wrong?
    thanks!
    Gabi.
    Boris Yamnitsky replied 14 years, 10 months ago 2 Members · 1 Reply
  • Boris Yamnitsky
    November 4, 2011 at 10:35 am
    Gabi, you may need to speak with out tech support on this one. We need to see your sequence, media type, etc. 888-77-BORIS
    Boris Yamnitsky
    BorisFX
