Activity › Forums › Adobe After Effects › Video Mosaic effect
Video Mosaic effect
Posted by Simon Levshin on July 28, 2008 at 12:18 pmHI everyone,
I saw this great effect here:
https://www.hopeactchange.com/mosaic (after it loads click on explore)
and was trying to figure out how to do this in AE,
Anyone have any ideas??
Regards
Simon
Patrick Hearn replied 18 years, 1 month ago 4 Members · 4 Replies -
Edward Barfield
July 28, 2008 at 2:10 pmTry the mosaic effect and play around with all the settings, such as number of horizontal and vertical blocks, blending mode (try difference, perhaps), and “mosaic” preset with cc toner.
Simon Levshin
July 28, 2008 at 3:09 pmOK thanks for that. I thought you’d need layer map though and use the luminosity values of the “footage” layer. I mean a compound effect perhaps that looks at another layer to effect. I want to map a bunch of images to a footage layer.
Thad Ciechanowski
July 28, 2008 at 3:23 pmThere is a stand alone program called “Mazaika” that creates the mosaic. It only does one image at a time however. So you would need to create a tiff sequence and then generate a mosaic for each frame. Then put all the stills in a timeline. Probably easier to use a NLE rather than AE for that last step.
This could take a while since you have to do each frame individually. And if there are a lot of inages, processing can take a while; so my hunch is they are using some other plugin or streamlined workflow. But the method I described will work.
Good Luck
Patrick Hearn
July 30, 2008 at 2:58 pmUsing a batch renamer on the resultant files from Mazaika or simply naming them numerically would mean you could just import as an image sequence rather than each image individually.
