Activity Forums Apple Final Cut Pro Video Monitor
  • Video Monitor
    Posted by Geoff Addis on January 19, 2020 at 2:50 pm
    Although not strictly pertaining only to FCPX, I would appreciate recommendations for a new 27 inch 4K display monitor for use with FCPX. HDR is not at the top of my requirement list, it would be a bonus. The new Apple HDR monitors are outside my budget, but I do wonder if the LG 5K Ultrafine monitor as supplied by Apple or the LG version of this monitor would give a reasonable indication of Rec709 colour, again Rec2020 would be welcome. Alternately, would I be better advised to get a 4K tv, although I have yet to discover one that is 27 inch in size. Also, would it be better to have either a Black Magic or AJA 4K interface rather than connecting the monitor directly to a Thunderbolt connection on my iMac?
    Thanks in advance.
    Morten Carlsen replied 6 years, 2 months ago 3 Members · 4 Replies
  • Eric Santiago
    January 20, 2020 at 3:55 pm
    Anything that size would be expensive.
    I have an Eizo 24″ CG247X HD for external and that does wonders with FCPX and others.
    However, a bit pricey at 2K USD.
  • Morten Carlsen
    March 11, 2020 at 11:56 am
    I have an 5k Ultra Fine from LG which is amazing. I also can recommend LGs true 4k (4096 Pixels) computer monitor. Both aren’t too expensive.
    Pro Color Monitor – Get Your Color Balance Right
    Get it on the AppStore Today->
    https://apps.apple.com/de/app/pro-color-monitor/id1495383011?l=en&mt=12
  • Geoff Addis
    March 11, 2020 at 5:16 pm
    Thanks for the responses. I ended up getting a BenQ SW271 monitor and have calibrated it using an x-Rite i1 Display Pro. Interestingly, the calibrated display is VERY close to the monitor’s in built Rec709 setting. Colours appear to be accurate although the black level could be a little lower.
  • Morten Carlsen
    March 11, 2020 at 5:20 pm
    You might also wanna try my Software Color Balance Monitor Pro Color Monitor.
    You can check it out in my signature ☺
    Been color grading since about 20 years and grew tired of histograms and what not and color profiles, monitors etc…. And ended up creating this tool !
    — Best Morten
    Pro Color MonitorGet Your Color Balance Right
    Get it on the AppStore Today — Pro Color Monitor MacAppStore
