Activity › Forums › Broadcasting › Video mixer in for HD
Posted by Daniel Sepulveda on July 26, 2010 at 8:22 pmHi,
Our production company owns two XDCAM EX PMW-EX1, and we are starting the production of a new TV show. We need a way to mix video (switcher) to be used with these two cameras, but in HD. What I have found on the internet is way to expensive (us $8000 and up). Does anyone know an affordable HD video mixer? Or any affordable solution for mixing two live video streams (maybe through software)?
Than You
Kasper Skårhøj replied 15 years, 2 months ago 7 Members · 7 Replies -
Bob Zelin
July 27, 2010 at 12:37 am$8000 is inexpensive. Normal switchers cost over $25,000 and up (and I mean all the way up). You are looking at wonderful products from Roland (Edirol), Panasonic, and For-A. The next level up is Broadcast Pix and Ross. Then it goes hi end like Snell and Wilcox, Grass Valley, Sony, and other brands you can’t afford. $8000 is inexpensive. I think that the Newtek Tricaster is in this price range too.
Bob Zelin
Richard Crowley
July 28, 2010 at 10:32 pmI have a Panasonic AW-HS50 on order for my ultra-portable HD production unit. $4000. Great features.
https://www.panasonic.net/pss/broad/product/switcher/aw-hs50/index.html
Maurice Jansen
July 31, 2010 at 1:41 pmnow that’s a cute little mixer
will it grow if you feed it 😉nice spec’s though
grt
MauricePeople saying they don’t make mistake’s often make nothing at all!
Richard Cardonna
August 3, 2010 at 4:36 amCheck avtake.com
they have a hd 4 camera mixer. its software using deckilnk cards. it’s workflow similar to a low end broadcastpix or tricaster but the video is superb. With hardware it could cost you close to 4k but will give you more than any hard panel system in that price range and higher.
All monitors are in the program but you can add an external monitor for clients.
You can insert video clips,images,titles from the hard drive.
If you use photoshop or gimp for titles the system automaticaly updates it on the program monitor. You can recored to hdd in avi or mpeg while streaming multigraph video to the internet on any encoder, you can also use external mointor or projector.
This will also up and down convert on the fly and works progresive and interlaced from 720×480 up to 1080.
They have a trial but the sd and hd version only work if you have at least 1 decklink or bm card. the dv version is firewire they all have the same interface.
RC
rc
Kasper Skårhøj
September 25, 2010 at 4:28 pmHi there,
I have been lurking the net for months to see if any real person had a real review to offer of the AW-HS50. So far I found none, but now I own one unit myself – and can share my experiences!
I’m totally blown away with it! I love it. I just love it! I was wondering for a long time while it was on order how it might eventually not meet my bloated expectations but it met them all and more! The only drawback I can find is that it makes a bit of noise (but orders of multitude less than a Tricaster or Broadcast pix I have tried!) with the fan and judging from the cool air it blows out it feels a bit overkill to cool it so much. If you are handy and dare to, you can probably mod it…
Anyway, if what you are looking for is 5 channels of HD in a compact form factor, the whole Panasonic 50’er series is it.
More specifically, you should notice that you configure the system for a certain HD or SD quality. For instance if you choose “1080i50” you better input 1080i50 into it – otherwise the input remains black. There is only a scaler on the DVI input.
Anyway, you can read for yourself what the manual says:
https://dl.dropbox.com/u/3261603/AW-HS50E_Basics.pdf
https://dl.dropbox.com/u/3261603/AW-HS50E_Operations.pdfI should add that so far the software worked and there seemed to be no bugs.
– kasper
Tony Leja
May 31, 2011 at 3:09 pmI know its been a bit, but your dropbox links are valid anymore. DO you still those pdf files for the Panasonic AW-HS50?
