Activity Forums Apple Final Cut Pro Legacy Video Media Storage – Internal vs. External?
  • Video Media Storage – Internal vs. External?
    Posted by Michaelhelenek on November 7, 2005 at 10:12 pm
    I will be purchasing a new Dual 2.3 GHz Powermac and other components for a video editing system. I will primarily be editing DV and HDV, however on occasion may encounter SD or HD.
    Given the capacity for 1TB of internal storage in the new G5, I question if I can use the internal drive as my media drive instead of purchasing external storage.
    1. Is the new internal drive fast enough for DV, HDV, SD, and HD?
    2. Is making a software RAID configuration between the 2 500GB internal drives beneficial? Will it enhance the video performance? Is it possible, given the application and media files will then be on the same drive?
    3. What benefits would external drives (price comparable) serve over this – if any? Is SATA connection necessary or can Firewire 800 cut it?
    Thank you for your insight.
    Michael Helenek.
    Michael Helenek
    Video Editor
    Walter Biscardi replied 20 years, 10 months ago 4 Members · 3 Replies
  • David Battistella
    November 7, 2005 at 11:03 pm
    yes.yes. no.no.
    No, you should never run the software and the media onteh same drive.
    no.see above
    You should never do this. ever
    You are best to go wth a SATA raid. With that you will get SD but not HD speeds. and expandable cheap fast storage. (it is not protected though. For DV, SD you can also go with a firewire 800 raid.
    David
  • Enzo Tedeschi
    November 8, 2005 at 6:22 am
    For my money, external SATA SCSI seems a good compromise between cost and performance if you’re doing uncompressed SD. FW800 can have performance issues (ie dropped frames) when your drive starts filling.
    Obviously this will blitz DV!
    HD capable drives are a huge price jump…
    :o)
    e.
  • Walter Biscardi
    November 9, 2005 at 2:18 pm
    I’ve never been a fan of internal storage, I just find that speed and performance are simply greater with external storage.
    For all the way up to 8bit uncompressed SD you can’t go wrong with the G-RAID’s and LaCie Big Disk series of FW 800 units. If you stripe two units together you can even do 10bit reliably. The G-RAID’s hold their speed the longest of any FW800 drives I’ve run due to the Medea technology they share. I can run the G-RAID’s to about 90% full before they start showing performance issues.
    For the ultimate in external storage, Fibre Channel is the way to go. I run the Medea FCR2X (2 TB) with speeds up to 375MB/sec. The newer 4gig units are going to be even faster. For real-time, there’s nothing better than the fastest units you can purchase.
    Walter Biscardi, Jr.
    “The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
    rsvp@biscardicreative.com to reserve seats.
