Activity Forums VEGAS Pro Video Media Generator window for VEGAS credit roll is cut off, section of screen is missing or not accessable
  • Video Media Generator window for VEGAS credit roll is cut off, section of screen is missing or not accessable
    Posted by Ralf Hermann on August 25, 2018 at 1:02 am
    Using Vegas Movie Studio15 Platinum
    Windows 10
    Tried different screen settings and different monitor, still some section remain missing.
    Anyone with a suggestion ?
    Thank you.
    Jorma Nippala replied 8 years ago 5 Members · 4 Replies
  • Graham Bernard
    August 25, 2018 at 3:16 am
    [Ralf Hermann] “Anyone with a suggestion ?”
    From my own experience and reading about this issue, here are several remedies you can try in progressive steps:
    1) Determine your edition of Microsoft’s .NET Framework . I installed the latest and continue in keeping up to date with. If you’re not confident working at this level then rather start from 2) . Check result.
    2) Ensure you have the latest Build. If not install. Check result.
    3) Factory Reset. Check result.
    4) Reinstall. Check result.
    I’m hoping 1) above should do it. It did for me. But you do it at your own risk. If you are not confident then rather start from 2).
    Keep us informed.
    * Grazie
  • Paul Berk
    August 25, 2018 at 3:37 pm
  • John Rofrano
    August 25, 2018 at 7:03 pm
    This usually happens when you set the DPI on your Windows fonts beyond 100%. Have you set the DPI on your Windows fonts to anything other than the default (100%)? Messing with Windows fonts and DPI is the usual cause for windows being cut off like that. The other is graphics card drivers.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Jorma Nippala
    August 25, 2018 at 10:21 pm
