Activity Forums VEGAS Pro Video Mastering for DVD
  • Video Mastering for DVD
    Posted by Unkhakook on March 10, 2006 at 4:31 pm
    Hi everyone,
    I’m in the final phases of post and color-correction for a movie I’m editing (called “What is INDIE?”) and I wanted to get some information on making sure that my video will conform to proper tech specs. I’m a total n00b at this, but am a pro audio editor, and have managed to transfer my audio skills quite well (I think) to the video editing world (check out the trailer at http://www.whatisindiemovie.com )
    That being said, I am editing DV footage using Vegas 6. We will be authoring the DVD using DVD architect 3. Here are my questions:
    1) what is the “proper” widescreen ratio? I know it’s probably 16:9. but when I use that ratio, I get some bleed thru of certain tracks on the top and bottom edges. When I use the “Academy aspect” ratio (1.89:1 I think) all is well. Is this ratio ok to use?
    2) what is the proper procedure for rendering a non-letterboxed widescreen version of the film? For the previews/ dailies I am just rendering a letterboxed 3:4 version. I have read some Vegas instructions that say to render it thusly as DV, then re-render to MPEG using your final ratio and telling it not to letterbox. I would rather avoid this recompression step and render directly to DVD-A compliant MPEG2 for authoring (especially since we are using red titles). Can I do this?
    3) what is the proper plugin and preset to use for titles/ graphics etc to “clamp (?)” the whites and blacks? Should I use this plugin on my camera footage tracks as well? (the final medium is DVD, but it may go to theatres and tv eventually)
    4) what is the proper audio range for the dialogue? For the music? Should I be normalizing all the way to 0dB? I assisted some post at Technicolor and most of thte dialog was around -9 to -12, with transition music and SFX being slightly louder.
    5) what about encoding my MPEG for DVD-A at 24p? Can I burn a DVD for playback at 24 frames per sec? (the originial footage is standard 29.97)
    6) If I use any “film look” plugins, such as Magic Bullet or Sony’s Film Grain, are there any issues (besides render time!) I should be aware of?
    7) if I want to set up my other networked computer to help with the render, do I need all the same plugins installed on both computers?
    Lots of questions! Any help grrrreatly appreciated.
    Unk.
    Unkhakook replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
