Activity Forums DSLR Video Video Looks Flat on Computer
  • Video Looks Flat on Computer
    Posted by Elliott Powell on August 3, 2012 at 4:25 pm
    Hi everyone I just joined this forum because I have a problem I’ve been wondering about for a while now. I use a Sony A77 with an 18-250mm lens, and on my camera screen my video look wonderful. However when I upload the footage (AVCHD 1080/60p) to Premiere it looks very soft and flat. Photos when I upload to the computer look just as good as on camera.
    I checked to see if it had something to do with how I uploaded it by looking at footage I imported to premiere from my hard drive (which is external if that matters) and comparing to the same footage straight from my camera (plugged into my computer with a usb) and it looked the same. I thought it could be my monitor but other peoples videos with the same camera on youtube look great (with no color correction), while mine don’t. I also looked at it on other computers and it still looked the same.
    This is an example of what I’m talking about https://www.youtube.com/watch?v=2AdvNmygPck and this is one of the videos I was comparing it to https://www.youtube.com/watch?v=FPP7w7_HBpQ&lc. I have an iMac if that matters and both of those videos used the standard creative filter. Thanks for any help!
    Paul Esteves replied 14 years, 1 month ago 2 Members · 3 Replies
  • Paul Esteves
    August 6, 2012 at 4:07 pm
    Lighting, settings, lenses, etc. All of those play a huge factor. The LCD on the camera can be quite misleading as its small and it often adds brightness so that you can see it more clearly. I’m not sure how confident you are as a videographer? But, I’d suggest reading a bit about settings and how to shoot on a DSLR.
    The lighting in the second video is very different to the lighting in your video. I mean the natural lighting and the way it was captured.
  • Elliott Powell
    August 6, 2012 at 4:56 pm
    Yeah I noticed that when there is a lot of light its not as much as a problem. Are you saying I should try overexposing a bit when it looks right on the LCD? Also I think part of the problem might be how I’m uploading to youtube, because if you compare the two videos at 360p, his looks a lot cleaner, so any tips on export settings? I tried a lot of different things with that with no significant change.
  • Paul Esteves
    August 6, 2012 at 8:43 pm
    I’m not too familiar with Sony DSLRs. Do you shoot on full manuel or does it set the exposure for you? What kind of aperture are you using when shooting this video? What is your shutter speed?
    As for the uploading issue. If when you bring the footage onto your computer it does not look like you want it to look, then it’s not your exporting. Does it not look right in Premiere before export? If not, then don’t worry about your export settings.
    I have a canon 60D. When I shoot video in the same locations as I shoot still shots, if I use my settings correctly, the video comes out with the same lighting and image quality. However, I often have to change the settings for video. I usually bump up my ISO and increase my shutter speed.
