Activity › Forums › Adobe After Effects › Video looks brighter in AE than FCP
  • Video looks brighter in AE than FCP
    Posted by Jessica Pearson on November 4, 2005 at 2:43 pm
    Hi there-
    I can’t seem to figure out what I’m doing wrong. I’m making a comp using a video clip. After I export and bring it into FCP it looks brighter than the original clip. Basically I have the clip in FCP up to a certain point, then halfway through it switches over to the AE clip and you can see a shift in color. It happens whether I use DV, Uncompressed, Animation whatever. What is After Effects doing to my video clips?
    Jessica
    Jessica Pearson replied 20 years, 10 months ago 2 Members · 2 Replies
  • Steve Roberts
    November 4, 2005 at 3:06 pm
    This is a known color space issue: AE processes in RGB, while FCP processes in YUV.
    Until these two kids process in the same color space, we need to tweak the colors manually. Search the COW for “RGB” and “YUV” and you should find more info on the matter.
    Yep, it’s annoying.
    Steve
  • Jessica Pearson
    November 7, 2005 at 3:17 pm
    Wow, thanks for the advice. It’s what I thought but wasn’t sure, I will work around the issue.
