Activity Forums Apple Final Cut Pro Legacy video levels spike after rendering sequence…
  • video levels spike after rendering sequence…
    Posted by Jonathan Potts on October 6, 2008 at 11:54 pm
    I was wondering if anyone can shed light on an issue that I have been experiencing. I’m using Final Cut version 6.0.2. I am converting footage that was shot in 4:3 to anamorphic 16:9. In order to do this I create an anamorphic sequence, drop the 4:3 footage onto it, and then do a digital zoom of about 136% to make the footage fill the screen. I check the video levels to make sure nothing is above 100%. Everything looks fine, and I am ready to render. Here’s where the problem happens– after rendering, the video levels magically jump up above 100%. They were fine before, but now they need adjusting!?! So, I apply the proc amp filter. Immediately, before I even adjust the filter, the levels drop back to where they were originally. So, I re-render the sequence, and the same thing happens again– the levels jump back up above 100%. I believe that the digital zoom is somehow causing this problem, and I can’t figure out how to get around it. The frustrating thing is that I am unable to get an accurate video level reading prior to rendering, because the very process of rendering is altering the video levels. Any thoughts?
    Jonathan Potts replied 17 years, 11 months ago 2 Members · 2 Replies
  • Jaap Verdenius
    October 7, 2008 at 7:28 am
    Maybe this workaround is useful:
    -in the browser, select the 16:9 clip find the column for ‘anamorphic’ and deselect it
    -open the 16:9 clip in the viewer
    -in the motion tab, set scale to 133 and aspect ratio (under distort) to -33
    -select the clip again in the browser and rightmouse ‘export quick time movie’
    -reimport the exported clip. Now you have a genuine 4:3 version of your 16:9 clip and you can avoid this level hiccup.
    Jaap
  • Jonathan Potts
    October 7, 2008 at 4:21 pm
    Thanks for the tip– much appreciated!
