Activity Forums Adobe Premiere Pro Video level shift after render?
  • Video level shift after render?
    Posted by Laco Gaal on April 23, 2013 at 7:26 pm
    I’ve imported a DPX sequence into premiere. Monitoring the DPX on the waveform it looks like this: https://d.pr/i/WN5M
    After rendering out to Prores, or MXF, it looks like this: https://d.pr/i/H3UH
    Even if I have the video limiter effect on the video track.
    What could be the problem? (tried rendering every possible ways)
    Laco Gaal replied 13 years, 5 months ago 2 Members · 4 Replies
  • Tom Daigon
    April 23, 2013 at 8:06 pm
    Im looking at the waveforms side by side. Where do you see a difference?
    Tom Daigon
    PrP / After Effects Editor
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
    http://www.hdshotsandcuts.com
  • Laco Gaal
    April 23, 2013 at 8:25 pm
    top, and bottom. Not a big change, but could be enough to create illegal levels…
    Here’s another example, check the vertical green line on the right: https://d.pr/i/Xv22
  • Tom Daigon
    April 23, 2013 at 9:01 pm
    Yes, I see that.
    Just a wild guess. Are you going from a 10 bit media to an 8 bit export codec?
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Laco Gaal
    April 23, 2013 at 9:04 pm
    Yes. 10bit DPX, or 10bit Prores to 8bit MXF.
