Activity Forums Boris FX Particle Illusion Video Length Issues
  • Video Length Issues
    Posted by Franz Vorenkamp on April 23, 2009 at 5:09 am
    I am exporting a video from after effects in uncompressed AVI format.
    It is 75 seconds long, or 1800 frames.
    When it is imported into particle illusion, it seems to misinterpretation the video- the end comes at frame 900, even when it is set to 24 fps like that video.
    What gives?
    I wish that after effects plugin would come out. This is very annoying to deal with- the moving in and out between programs.
    Theo Van laar replied 17 years, 4 months ago 4 Members · 5 Replies
  • John Holste
    April 24, 2009 at 12:57 pm
    Franz,
    I have never used an uncompressed avi I wonder if that is the issue? Try a lossless compressed avi, if you are worried about quality issues.
    John
  • John Holste
    April 24, 2009 at 12:59 pm
    Franz,
    Quote from Alan “…Lagarith uses lossless compression (like a ZIP file). Uncompressed just doesn’t make sense…”
    John
  • Theo Van laar
    April 27, 2009 at 9:57 pm
    John,
    I don’t understand your comment to Franz about uncompressed avi. The problem of Franz is that his output file is only half the expected length. I see exactly the same in PI 3.0.4.1: the output file is only half the length as would be expected from my settings. I’m working in PAL and use the Lagarith codec.
    I hope that Alan Lorence has a solution for this.
    Theo
  • Alan Lorence
    April 27, 2009 at 10:18 pm
    If you have a 30 frame video, does pI3 see it as 15 frames long?
    Is it a fields issue? (Try rendering in AE without fields and see if that fixes it.)
    Alan.
    http://www.wondertouch.com
  • Theo Van laar
    April 28, 2009 at 4:59 pm
    No, it is not a field issue. I will rebuild the project from scratch and see if that solves the problem.
    Theo
