Activity › Forums › Adobe Photoshop › Video layers menu not showing in Photoshop CC
  • Video layers menu not showing in Photoshop CC
    Posted by Davıd Coccıante on May 13, 2014 at 10:51 am
    Hello,
    Under the Layers menu in Photoshop CC, the Video Layers menu doesn’t show up as it is supposed to (so I can’t create new video blank layers). Why is that? Is there an extended version of Photoshop CC? I thought Adobe removed the “extended” option on Photoshop.
    I’m running Photoshop CC on a 2013 Mac Book Pro 15” Retina with Mac OS 10.9
    Davıd Coccıante replied 12 years, 4 months ago 2 Members · 2 Replies
  • Jack Lykins
    May 21, 2014 at 7:51 pm
    Hi David,
    Have you found a solution to this problem? I’m having the same issue in CS6 (not the extended version).
    Thanks.
  • Davıd Coccıante
    May 21, 2014 at 8:15 pm
    Well if you don’t have Photoshop CS6 Extended you don’t have video and 3D. Photoshop CC removed the “extended” option but video and 3D is still removed when you crack the software apparently
