Activity Forums Apple Final Cut Pro Legacy Video in 24p and audio in 30
  • Video in 24p and audio in 30
    Posted by Mauro Moreira on April 30, 2011 at 3:13 pm
    Hey guys, i`m working in a project and now i got a real problem.
    All footage is recorded in 24p (5d) but some pieces of the audio are in 30 frames, and i`m having troubles to sync it….
    Does anyone knows a solution about this?
    Its a huge project, so i think i`ll have a lot of audio recorded in 30frames.
    Mauro.
    Jeremy Garchow replied 15 years, 4 months ago 3 Members · 4 Replies
  • Chris Tompkins
    April 30, 2011 at 3:42 pm
    Audio is not recorded in frame rates.
    How did you record the audio?
    Have you looked into Plural Eyes?
    Chris Tompkins
    Video Atlanta LLC
  • Jeremy Garchow
    April 30, 2011 at 11:47 pm
    Audio doesn’t record in fps, it’s all about how you import it to FCP in the first place. See here:
    https://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
  • Mauro Moreira
    May 2, 2011 at 6:38 pm
    Thanks guys, i`ll receive all the material today and try again.
    But know i`m happy to know that audio is not recorded by frame rate!
    I`ll let you know.
  • Jeremy Garchow
    May 2, 2011 at 6:40 pm
    [Mauro Moreira] “But know i`m happy to know that audio is not recorded by frame rate! “
    The files can be “stamped” with a certain frame rate/tc, and that can affect sync, but one second of audio is one second of audio. If you import the audio correctly, it should sync no matter what tc it was originally recorded with.
    Jeremy
