Activity Forums Adobe After Effects Video imported from AE into FCP skips frames
  • Vladislav Gomzyakov
    May 15, 2010 at 1:13 am
    We’ve done that, but nothing changes. Tried all kinds of alpha channel settings, still no luck. I don’t really know what is even causing this.
  • Bret Williams
    May 15, 2010 at 12:01 pm
    Why is there a render needed at all? Did you render at a different frame rate than your sequence? Example 60p placed in a 30p sequence. It’s going to skip every other frame.
    May 15, 2010 at 12:51 pm
    What do you mean why is it needed? Doing a project like that..
    No, both rendered at 23.98. I tried using even the same codec, but no use.
    May 19, 2010 at 4:03 pm
    Im using compositions without any footage though. Tried a bunch of different options of rendering. And still for some reason when I put it into FCP it skips every second frame. This is so bad, cause I did all this work and now we cant use it((
    May 19, 2010 at 4:27 pm
    And I noticed when I rendered it in HDV 720p60 and put it in it worked fine. But when I used an alpha channel on top of it or used color key filter to erase background colour, it started skipping frames again. WTF!
    May 19, 2010 at 6:10 pm
    So I was able to solve it by rendering it as Photoshop sequence with including alpha channel.
