Activity Forums Broadcasting video hot
  • video hot
    Posted by Mark Mcdonald on June 22, 2007 at 5:24 pm
    Okay I’m stumped.
    We are a broadcast facility and trying to avoid using videdotape.
    we acquire using digital cameras, import via firewire or sdi Edit FCPS 2 and then push to our
    Master Control using a “NEXGEN” system.
    Here’s the problem. After the edit we drop a broadcast safe filter(level set at 99%) on everything and send it to Cleaner 6.5. Make an .m2v of it and push it to the system.
    when the system gets it the levels are HOT, reading as much as 120%
    I’ve checked the compressor settings, nothing added to brightness or gamma
    We’ve tried adjusting the filter to be more aggressive with no change.
    Anyone run accross this problem???
    Mark McDonald
    WKRC-TV
    Mark Mcdonald replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
