Activity › Forums › Apple Final Cut Pro Legacy › Video glitch on export.
Posted by Ted Haines on May 9, 2011 at 10:25 pmI’m exporting a ProRes 422 sequence from Final Cut as a quicktime movie (no conversion). Everything plays fine in the sequence. The exported file zooms just before some of my edit points. Anyone ever experience this?
Jerry Hofmann replied 14 years, 3 months ago 3 Members · 3 Replies -
Jerry Hofmann
May 10, 2011 at 3:22 pmWhat was the source footage’s properties? i.e. DV? DSLR HDV or? Did you record to ProRes files (like with a Ki Pro) or did you transcode it? if so how?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Errol Lazare
June 20, 2012 at 6:02 amI am also experiencing a glitch after exporting as a quicktime movie. It is somewhat of a Mozaic glitch for one frame after each edit point. Have you ever experienced this Jerry? I am on a mac 8-core 2.4 GHz processor. In my case I am editing XDCAM 35 mb/s which was transcoded from H264 footage. It only seems to happen on this particular editing suite.
The only difference between this edit suite and my others is that my editing drive is stripped with 2 drives.
Let me know if you have experienced this.Errol X. Lazare
EXL Films
http://www.exlfilms.com -
Jerry Hofmann
June 20, 2012 at 1:29 pmMight try resetting your graphics card. I’ve seen this fix the problem. Not had it in a long long time though.
I thing too the h.264 to XDCAM transfer is possibly suspect too. GOP to GOP. I’d be transcoding and working in ProRes instead of XDCAM if you can. i frame media formats such as ProREs or DVCPROHD are a lot easier on your computer to work with for sure.
Jerry
Current DVD:
