Activity Forums Adobe Premiere Pro Video Ghosting Repair
  • Video Ghosting Repair
    Posted by Dan Sudkamp on September 9, 2016 at 6:00 pm
    Hello all, and thanks in advance.
    Working on a project and noticed that one setup has some odd ghosting going on. It’s showing up on every take on this setup and only this setup. The action here is the judge walking in and sitting down and as she moves across the frame a “ghost” of the chair briefly appears on her gown on her right shoulder, shown below.
    Two questions, really:
    1) What would cause this to happen?
    2) What can I do in Premiere to fix it, if anything?
    I don’t *have* to use this shot, but I would like to, if It can be cleaned up some. I tried some basic Lumetri work to bring down the blacks, but the levels had to go down to extreme lows to get rid of the ghosting. And also, we would generally just like to get an idea of what may have caused it so we can avoid a similar situation in the future.
    Any and all help is greatly appreciated, thanks!
    Duke Sweden replied 9 years, 11 months ago 4 Members · 6 Replies
  • Chris Wright
    September 9, 2016 at 9:44 pm
    clear media cache
  • Matt Quinn
    September 9, 2016 at 9:55 pm
    My first thought is was there a piece of glass in the optical path? A filter? Barrier? – Protective plate in the matte box?
  • Dan Sudkamp
    September 9, 2016 at 10:29 pm
    Thanks Chris. Unfortunately this in in the raw footage itself. But thanks for the thought!
  • Dan Sudkamp
    September 10, 2016 at 3:49 am
    This was my best guess also – I have an e-mail out to the DP hoping for some info that might confirm that. As I continued to edit, I noticed the ghosting on a few other shots that were pointed at windows, which has me thinking an ND filter in a matte box is the culprit. A bummer, but I just went ahead with the edit and cut around the bad clips.
    Thanks for the response!
  • Matt Quinn
    September 12, 2016 at 5:33 pm
    Some boxes have a slot or holder for a plain protective glass at the front. – They can cause havoc, but if you’re in a situation where a front element could get damaged, well what are you gonna do?
  • Duke Sweden
    September 12, 2016 at 7:10 pm
    Looks to me like a kind of “lens flare”. The light on the chair is bright enough that it causes a flare effect onto the judge’s robe.
