Activity Forums VEGAS Pro Video FX-problem applying adjustment to entire event
  • Video FX-problem applying adjustment to entire event
    Posted by Lazyolddog on May 1, 2005 at 11:56 pm
    I have read the Billyboy tutorial on use of Gamma-Brightness/Contrast-HSL and color balance to adjust events. I set my timeline cursor somewhere in the event and preview the changes as I adjust the plugins. Normally, it works just fine. Ocassionally it will adjust a few frames, but not apply the change to the entire event evenly. I can’t figure out why it seems to work sometimes and sometimes NOT. HELP.
    Edward Troxel replied 21 years, 4 months ago 2 Members · 1 Reply
  • Edward Troxel
    May 2, 2005 at 1:46 am
    Sounds like you are moving the curson on the color correction timeline and it is creating a new keyframe at that point. Therefore, everything BEFORE the keyframe will NOT be changed (or will gradually go from the unchanged values to the changed values).
    Edward Troxel
    JETDV Scripts
