Activity › Forums › Adobe After Effects › Video from Avid to After Effects
Posted by Erik on February 21, 2006 at 1:59 amHello all!
I am working with Avid Composer and After Effects 6.5 and has a video question. It seems that everytime I export video from Avid for use in After Effects, the video never looks quite as good in AE as in the Avid. My photographers are shooting on BETACAM Sx and I am importing the video from an SX deck into AVID at 1:1 OMF setting. I have tried many different exportation methods and nothing really seems all that great. I’m not as knowledgable about video as I should be and I am sure theres something I am missing. I was wondering if anyone was working with a similar set up and had an idea as to the best way to get the footage in AE. Its important i get the video into AE as cleanly for keying…Thanks in advance…
ErikErik replied 20 years, 7 months ago 3 Members · 3 Replies -
Chris Smith
February 21, 2006 at 3:15 amI don’t know MC, but in DS, I export video as quicktime (animation codec). But set the setting to ‘graphics’ mode because Animation is an RGB codec. Set it to ‘video’ mode if the codec you render to is YUV.
Same deal with import.
Chris Smith
https://www.sugarfilmproduction.com -
Carolyn Fusinato
February 22, 2006 at 6:45 pmHey Erik!
AVID recommends that “To use Avid source footage in After Effects, Adobe recommends exporting Avid clips in a movie format because QuickTime and AVI formats allow you to maintain the Avid compression” https://www.avid.com/onlineSupport/supportcontent.asp?contentID=3096
They also recommend capturing the footage at the best quality that you can. For a key that may be necessary, but most of the time I import footage at the settings that our editors edit in which is AVID Meridien 2:1 or AVID DV. If you don’t know if your editing system is lower field or upper field priority, test it. I use Tim Bowman’s handy Field Order Test found at https://netherlogic.com/tv_tools/.
The AVID DV codec is a little hard to get for the Mac. I installed the AVID DV Free ap in order to get it. You can download the Meridien codec off the AVID site. If you edit on the same platform that you’re working in after effects on then you can import the codecs from the editor’s computer.
Export Settings from AVIDs
Exporting from AVID Adrenaline
//Editing DV
Export As: Quicktime Movie
In Format Options:
Video Settings: Avid DV, Best Quality, Options:
(Color Input: ITU-R 601 (16-235), Resolutions:
DV25 NTSC 411), Frames per second: 29.97
Sound: Uncompressed, 48 Khz, 16 sample size, Stereo
Custom:
Video & Audio
Video Format: 720 x 486, Size to Fit
Color Levels: RGB
File Field Order: Lwr Field First
Display Aspect Ratio: Native dimensions (720 x 486)Exporting from AVID Symphony
//Editing 2:1 Compressed
In Format Options:
Video Settings: Avid Meridien Compressed, Best Quality, Options:
(Color Input: ITU-R 601 (16-235), Video Format: NTSC, Resolutions:
2:1 Interlaced), Frames per second: 29.97
Custom:
Video & Audio
Color Levels: RGB
Display Aspect Ratio: Native dimensions (720 x 486)//Editing Uncompressed
In Format Options:
Video Settings: Avid Meridien Uncompressed, Best Quality, Options:
(Color Input: ITU-R 601 (16-235), Type: Meridien Interlaced, Video Format: NTSC),
Custom:
Video & Audio
Color Levels: RGB
Display Aspect Ratio: Native dimensions (720 x 486)Render Settings from After Effects
For the Avid Symphony or AdrenalineIf comp has Alpha
Render Settings: DV Settings
Output Module: Avid Meridien Comp 2:1 +K StraigIf comp has No Alpha
Output Module: Avid Meridien Compressed 2:1For the Avid Newscutters
Output Module: Avid DVFor comp with Alpha, render 2nd mov that is alpha only
Output Module: Avid DV AlphaAE Output Module Settings
AVID Meridien Comp 2:1 +K Straig
Format: Quicktime Movie
Output Info: Avid Meridien Compressed, RGB Levels (0-255), NTSC, Resolution: 2:1 Interlaced, Spatial Quality = Most (100)
Channels: RGB + Alpha
Depth: Millions of Colors+
Color: StraightAVID DV Alpha
Output Info: Avid DV, RGB Levels (0-255), Resolution: DV25 NTSC 411, Spatial Quality = Most (100)
Channels: Alpha
Color: PremultipliedYou can see I convert from the editing YUV color space to RGB colors for compositing and back to YUV when importing back to the editing platform.
Don’t worry about stuff not looking good on your computer monitor. Your computer monitor is not the best to use for quality control for video. Send the signal out to a Broadcast Monitor from AE using Video Preview to tell if your adjustments are good. Also, AE just isn’t the best keyer out there. Third Party plugins might help.
-Carolyn
Carolyn Fusinato
http://www.fusinatodesign.com
