Activity › Forums › AJA Video Systems › Video freezes & skips during capture
  • Video freezes & skips during capture
    Posted by T.durden on August 12, 2005 at 7:51 pm
    The video that I capture thru my AJA Io LA freezes a few frames every couple of seconds. I’m running FCP HD 4.5 on a Dual GHz Power PC G5, memory 2GB DDR SDRAM. It dosen’t seem to be dropping frames (no warning comes up) I have several machines I can rout to the AJA & the video still “skipped frames”. I have no problem capturing thru my XL2/NTSC Firewire Basic
    T.Durden
    Bob Zelin replied 21 years, 1 month ago 2 Members · 1 Reply
  • Bob Zelin
    August 13, 2005 at 4:21 pm
    you do not specify what drive array you are using, nor do you specify what resolution you are working at. If you are trying to capture 10bit uncompressed from a Beta VTR on your internal drive, this will absolutely happen!
    Bob Zelin
