Activity › Forums › Apple Final Cut Pro Legacy › Video freezes on playback
Posted by Kurt Baird on January 15, 2009 at 6:21 pmI work on a Mac G5 with more than one user account. On one account, Final Cut Pro (5.0.4) functions normally. When I login to another account, the playback freezes while the audio still plays. I get no dropped-frames alert. I’ve checked all of the preferences, even with a separate, yet similar computer, and they are all correct. What do you suggest?
KurtJohn Douglas replied 15 years, 11 months ago 5 Members · 5 Replies -
Kevin Monahan
January 15, 2009 at 7:23 pmTrash Prefs FOR that user. Each user has their own FCP Prefs.
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Kurt Baird
January 15, 2009 at 8:46 pmTried it, no luck. However, I did solve the problem about a half our after posting the question. The solution might be helpful to others who encounter this same problem. In the top menu I opened Final Cut Pro > System Settings > and clicked on the Effect Handling tab. It displays a list starting with “Motion Jpeg,” DC30+ Lossless 4:2:,” “Photo-Jpeg” and so on, on the left. On the right of each item, it says “effects handled by:” then a drop menu. On several of these drop down menus, Final Cut Pro was not selected. I went to each one and selected Final Cut Pro and the program functioned normally after that.
Thanks for your quick response. I hope the info in this reply is helpful.Kurt
Bill Yahraus
March 9, 2009 at 12:17 amI have been having this same problem of the picture freezing and the audio continuing to play for months and have not been able to solve it. I am on OS 10.4.9, FCP 5.1, Quick Time 7.2. I have 4 external data drives in a FirmTek SeriTek/2eEN4 and a 320 GB drive in the computer, in addition to the boot drive. The RAM is maxed out at 1.5 GB in my G4 Dual Processor. I have trashed my preferences and even gone so far as to do a clean install of both the OS and FCP. I have been through the preferences over and over, but see nothing wrong… No luck.
It does not matter if I capture to the internal or external dives, the playback problem still occurs every once in a while. Even if I am only playing back a clip that has just been captured in the viewer and there is no timeline to overlap on the screen. I can stop, backup and play over the same spot just fine, so the problem isn’t long frames in the HDV I’m capturing as DV.
Any thoughts?
Bill -
Lev Mergian
August 24, 2009 at 2:23 pmHaving similar problem with with AVCHD that has been transfered into .mov files. It plays for about 4 seconds then freezes. If I pause and then play again it will pick up for another 4 seconds and freeze again. I tried copying files from external to internal drive and reconnecting the media but it doesn’t change anything. I have 2GB of RAM and 2.33Ghz Processor.
I have no trouble playing 720p clips, but for some reason these 1080 clips or just wrecking me. Please any help. This is no way to run a video business.
John Douglas
October 22, 2010 at 2:24 amIn a project I’m working on, playback on the timeline is freezing. WIth the clips I have picked, w/o music/audio, as I am playing for some reason I will get a freeze frame while it is still playing, and then a few frames and seconds later it picks up. I did have transitions on the clips, I have taken them off and it continues to freeze at different points on the timeline. I have multiple clips on the timeline (doing a highlight real) and as one clip ends and another clip begins, it will freeze for a few seconds and pick up in the middle of the clip and not at the beginning.
How can I get it to stop freezing and play smoothly through? What have I done wrong? Please Help!!
