Activity › Forums › AJA Video Systems › Video freezes every minute or so during capture.
Nick Balogh replied 20 years, 8 months ago 6 Members · 27 Replies
Gary Adcock
January 8, 2006 at 10:30 pm[Nick Balogh] “I got journaling turned off. I tried the Kona transfer test again and its still getting around 80mbs write and 130mbs read. This is with my warning light still on telling me one of my drives is about to fail. Do you think the breakdown of one of my modules would cause this”
glad you found journalling to turn it off.
yes a failed drive will decrease the raids ability to handle data.
and it will take a while to rebuild the raid after you put the new drive in – at least 12hrs.Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL USA -
Olivier Jean
January 9, 2006 at 11:33 amHi Nick,
Have you check this update out for the Xserve raid and video editing?
https://www.apple.com/support/downloads/xserveraiddriver10.html
that might do the trick, i would check the cables too, have you got access to new ones and a new card?.
Have you stripped the 2 LUNs of the Xserve as a raid 50?
Is this a new Xerve or an old one?Regards
Olivier Jean
Video Sales Consultant
Apple Certified Trainer Final Cut Pro 5
Powermedia Systems
Sydney Australia -
Olivier Jean
January 9, 2006 at 11:35 amHave you got the latest firmware??
Regards
Olivier Jean
Powermedia Systems
Sydney Australia -
Nick Balogh
January 9, 2006 at 4:51 pmYa..that was one of the first things I checked. I loaded that driver and checked the firmware. Its all up to date. Im looking into getting some new cables and I have already switched out the Fibre channel card. The xServe is about a year and half old. When I look in the RAID admin both sides come up Raid 5.
Bob Zelin
January 10, 2006 at 4:30 amNick –
how long do you want to keep this thread going ? There is something VERY WRONG with your drive array. You are not going to get any miracle answers on this forum that will make it start working. Replace your bad drive, and once it rebuilds, if you don’t get dramatically better performance from AJA Kona System Test, start from scratch – use RAID ADMIN to delete the RAID, and let it rebuild from scratch, and then TEST IT AGAIN. If you ignore this warning, and just keep going at 80mb/sec performance with a loaded XServe RAID, you are doomed for near future failure.What more can I say.
Bob Zelin
David
January 10, 2006 at 4:30 pmNick,
I know I mentioned this before BUT, would you please confirm that “allow host caching” is turned off (unclicked) in the performance tab in XRAID Admin/Settings. The problem you describe is exactly what happens to me when I load with “allow host caching” on. Remember, (for me at least) I HAVE to reset this EVERY time I go to load. (If anybody knows how to fix this let me know) Even with a bad drive, you STILL shouldn’t have the freezes you describe.
Please let me know.
David
Nick Balogh
January 10, 2006 at 7:27 pm[Bob Zelin] “How long do you want to keep this thread going ?”
To answer Bob
