Activity Forums Adobe After Effects Video Format Question
  • Video Format Question
    Posted by Frank Cia on April 4, 2011 at 9:32 am
    I’ll be making a video (motion design) for a client that will be distributed (through dvd) on Australia(PAL), Europe(PAL/NTSC) and USA(NTSC).
    I’m using After Effects and I’m not sure which format to work on.
    I’m planning to deliver 2 versions one PAL and NTSC.
    The project is long, so I can only afford to work on one (NTSC or PAL). Then I’m planning to convert from NTSC to PAL or vice versa.
    Should I go with PAL 24 frames or NTSC 30 (29.97) frames?
    Interlaced or progressive? Square or non-square pixel?
    Thanks in advance.
    Frank Cia replied 15 years, 5 months ago 2 Members · 2 Replies
  • Michael Szalapski
    April 4, 2011 at 6:02 pm
    Is this HD or SD? Is there video footage or is all of it motion graphics you create in AE?
    I would work in whichever format you want and then nest your comp in the comp of the other frame rate when you’re ready to render that country’s version. AE simply interpolates the keyframe data so it works out really nicely.
    Oooh, ooh, I just remembered! Read this thread: https://forums.creativecow.net/thread/2/997997#998002
    They were discussing this very thing.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Frank Cia
    April 5, 2011 at 4:35 am
    Thanks Michael. That was very helpful.
    I might create it in 1280x720p, all graphics in AE, there might be a need to add stock videos (this is where the frame rate issue comes in I guess).
    Thanks for linking me to that thread, very helpful indeed.
