Activity › Forums › Adobe After Effects › Video Format
Video Format
Posted by Richard Stegall on September 8, 2009 at 3:41 pmWhat video format gives you the best work flow, quality and render times?
Richard
Richard Stegall replied 17 years ago 3 Members · 3 Replies -
Steve Roberts
September 8, 2009 at 4:03 pm“Format” is pretty broad.
You deliver in the format requested by your client. Maybe you mean “codec”?
If so, then you should work in the highest-quality codec your system can support. If you’re editing video, you want to use the codec your system can play back. For example, I can’t play back uncompressed 1080i, but I can play back DVCPROHD 720p. Regarding AE, since instant real-time playback isn’t possible with any codec in AE, you can work in uncompressed HD or RED if you have to — AE has to render everything.
Usually AE artists work in a high-res intraframe codec such as Animation, PNG, Photo-JPEG, 8-bit uncompressed or similar to avoid recompression. Then they render to a codec required by the editor or editing app.
In AE, don’t work in interframe-compressed codecs such as MPEG-2 or HDV.
If you need more info, let us know.
Anybody else?
Todd Kopriva
September 8, 2009 at 10:00 pmI second what Steve said.
Consider—as he suggested—that you have input formats, intermediate formats, and output formats. Each has its own principles that govern which is best. The last of these three (output formats) is sometimes constrained by things like bandwidth to your audience or client demands. You can usually choose intermediate formats based on what works best for you. Input formats… well, sometimes you just take what you get.
I cover this at a high level in “Planning your work”, which links to a great article by Aharon back here on the COW.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Richard Stegall
September 11, 2009 at 3:32 pmThanks for the replies. I made some adjustments to footage and my work flow is much smoother and the render times have decreased.
