Activity Forums Adobe Premiere Pro Video flicker. Need help fast
  • Video flicker. Need help fast
    Posted by Ron Weber on April 30, 2006 at 12:14 am
    Okay here’s the problem. It’s the eleventh hour and Houston we have a problem. I rendered out several music videos in one timeline for a demo showing Sunday. The avi was solid when I checked it in media player. Using Encore 1.0 I burned the DVD using the avi and set the transcoding to 16:9 8mb CBR 1 pass. In a couple of section of one of the videos several frames flicker for a couple of frames. One even freezes for sveral frames. The flicker occurs after a still image and after a section of black video. The one section that freezes is at the begining were I have noise applied. Now in the other sections of video were I have black video to video theres no problem. So I thought it might be the bit rate. I tried them all. I even did automatic and it’s still there. I’m viewing it on a set top DVD player. Any help to resolve this tonight? Thanks to everyone that helps.
    Tip Mcpartland replied 20 years, 4 months ago 3 Members · 6 Replies
  • Ron Weber
    April 30, 2006 at 12:21 am
    I noticed something else. When I imported the avi and played it in the timeline of Encore the video plays fine except when it comes to the part where the problems are. Then it’s no interpeding it properly.
  • Tim Kolb
    April 30, 2006 at 3:10 am
    …but Media Player plays through those sections?
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Ron Weber
    April 30, 2006 at 6:09 am
    yes it does without showing any flckering. I played it back in encore’s monitor, when you scrub through it slowly you don’t see it but when you play it you can see that for several frames it oly displays one field. When you pause it on that spot you can see that only half the fields are displayed.
  • Tim Kolb
    April 30, 2006 at 6:46 pm
    Could the frame dominance be set wrong in Encore?
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
  • Ron Weber
    May 1, 2006 at 12:59 am
    How do I check that?
  • Tip Mcpartland
    May 1, 2006 at 8:38 am
    Long shot, but I just fixed a similar problem by refreshing the “plugin file” or something similar. You can get the direct information by going to the Adobe website, going to the Premiere Pro section, and searching for digital video troubleshooting.
    But you really don’t need to. You just hold down the shift key while you open the application. This may have worked so well for me because I edit in Cineform Aspect, but maybe you do too.
    This made a lot of difference as I was having some strange stuff going on, halting video, freezes and really weird stuff when I applied transitions.
    Tip
