Activity Forums VEGAS Pro Video file exported from Vegas corrupted after some time
  • Video file exported from Vegas corrupted after some time
    Posted by Juan Juig on February 4, 2018 at 1:15 pm
    Hello,
    here are the metadata of an mp4 video that was exported from Sony vegas 11 pro on Windows 7 ultimate. The video file played fine in all video players after the export, everything seemed alright.
    However after a few months I wanted to open the video and found out that it was somehow corrupted. All the metadata is still there, but the video cannot be opened by any video player (VLC only shows black screen, no audio is played), and cannot be imported into any NLE software. This is the second time this has happened to me.
    Each time the exported video was over 1 hour and 30 minutes long, each time it was exported with similar mp4, h264 settings, each time it was exported from vegas, and each time after a certain amount of time it went corrupted. I did nothing special with the file except I moved it from one location on the local hard disk to antoher location. Could that be the cause of this?
    The export settings were the following:
    MainConcept AVC/AAC
    Video settings:
    Frame size: HD 1080p (1920×1080)
    Profile: Main
    Frame rate: 25.000 (PAL)
    Allow source to adjust frame rate.
    Field order: None (progressive scan)
    Pixel aspect ratio: 1.0000
    Nuber of reference frames: 1
    Constant bit rate: 28 000 kbps
    Encode mode: Render using CPU only
    Enable progressive download.
    Audio settings:
    Sample rate (Hz): 48 000
    Bit rate (bps): 320 000
    Thank you,
    Juan
    Juan Juig replied 8 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
