Activity Forums VEGAS Pro Video fading out–Strange
  • Video fading out–Strange
    Posted by Jim Murphy on December 2, 2012 at 12:51 pm
    I put together a montage with a credits at the end. It looks fine in Pro 12 on the timeline. It looks fine when rendered and brought into DVDA. After I burn it to a DVD toward the end it will fade to black and stay black. I tried reburning a few times, then fast forwarded to the end to make sure it was not fading to black, and it looked normal. However, when I play it from the beginning to the end, it will again fade to black in the same area. What’s going on? Thanks, Jim
    Vegas Pro 12 DVDA 5.2 Excalibur 6
    Dell Quad Core 2.67 GHz
    John Rofrano replied 13 years, 9 months ago 2 Members · 3 Replies
  • John Rofrano
    December 2, 2012 at 1:17 pm
    [Jim Murphy] “I tried reburning a few times, then fast forwarded to the end to make sure it was not fading to black, and it looked normal. However, when I play it from the beginning to the end, it will again fade to black in the same area. What’s going on?”
    What are you watching the DVD on? Try a different DVD player. If fast forwarding to the end does not fade to black and watching from the beginning does, it could be something the DVD player is doing because the actual video cannot both fade to black and not fade to black (that’s impossible).
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jim Murphy
    December 3, 2012 at 2:54 am
    Yeah, it was the DVD player. Thanks, John. Jim Murphy
    Vegas Pro 10 DVDA 5 Excalibur
  • John Rofrano
    December 3, 2012 at 11:50 am
    [Jim Murphy] “Yeah, it was the DVD player.”
    I thought so. Once you eliminate the impossible, whatever is left, regardless of how improbable, must be the reason. 😉
    ~jr
