Activity Forums Adobe Premiere Pro Video exports from premier pro cc in very low quality
  • Video exports from premier pro cc in very low quality
    Posted by Michelle Gevint on July 18, 2017 at 7:36 pm
    Hello,
    I’ve been trying to export my video for the past week and I’ve tried so many different presets but the out come is always the same- a low quality video, lots of noise, grain flickering and I’m really at a loss…
    here is the info:
    I shot using multiple formats
    Mark 4d fps 29. 97
    Drone – 4K 50fps
    Animation which is 23.98 fps
    I know all these different format mean that I will have to deal with some loss of quality.
    The video will be viewed on a lg 43in uhdtv.
    Up to now I exported using different variations of these presets:
    1080by 1920
    H.264
    Custom
    Profile high
    Level 5.1
    Vbr 2 pass
    Played around with target and maximum bit rate
    Sequence settings are 29.97 frame rate
    What was hurt the most is the 4K drone footage and the animation. Both have so much noise. The original footage is so sharp and crisp it’s very frustrating to see it after the export. I know there’s going to be a down grade when exporting to 1080 but I just can’t believe it’s so much. It almost looks like an online YouTube clip. the animation is the same, looks very noisy.
    Looking forward to some help if anyone has any ideas! I’m going a little insane!
    Jon Doughtie replied 9 years, 1 month ago 3 Members · 2 Replies
  • Todd Perchert
    July 18, 2017 at 7:45 pm
    Have you tried High Profile 4.2? And are you using the “Use Maximum Render Quality” checkbox checked? I’ve had better luck not checking that.
    Use something like the Vimeo HD 1080P preset as a starting point.
    It should look good!
    Good Luck!
    TC
  • Jon Doughtie
    July 19, 2017 at 7:00 pm
    Don’t use “Max Render Quality” unless you scaling some footage up or down.
    What is you minimum/maximum bandwidth in your render settings?
    You are taking your 4K footage down to 1920×1080. If you are scaling that footage to fit 1920×1080, it is a quarter the size of your original 4K footage, so you will certainly lose some fine detail.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
