Activity Forums VEGAS Pro “video event pan/crop” dissapeared
  • “video event pan/crop” dissapeared
    Posted by Herman Kops on April 8, 2011 at 6:04 pm
    while working with SV i replaced the “video event pan/crop” window a little bit fast. it dissapeared left of the screen (i can´t see it anymore) and i can´t get it back with the cursor.
    somebody knows how to fix it?
    thanks
    from catalunya -spain- with love
    Herman Kops replied 15 years, 5 months ago 2 Members · 3 Replies
  • Matt Crowley
    April 8, 2011 at 7:41 pm
    It might be stuck under your taskbar at the bottom of the screen. Make your taskbar auto-hide (unlock it and drag the top edge of it down so it shrinks to a thin bar), then you might be able to see your pan/crop window and drag it up onto the screen.
  • Herman Kops
    April 8, 2011 at 8:44 pm
    thanx, this is not the first time it happened to me, before i solved the problem in this way (after a lot of trying ;).
    but … now the pan/crop dissapeared on the left side (if activating again i can see it dissapears about in the middle) of the screen.
    – i also closed the program but it starts up in the same position.
    – maybe stupid but i also tried to replace the horizontal position of the monitor but it doesn´t work.
    is there no way to reset it?
  • Herman Kops
    April 9, 2011 at 7:42 am
    next morning…, after the night before closing SV and PC, the window “pan/crop” showed up again.
    too simple to be true.
