Activity › Forums › Adobe Premiere Pro › Video Effects applied to MultiCamera Clip
  • Video Effects applied to MultiCamera Clip
    Posted by Mark Hubert on May 17, 2013 at 5:15 am
    So I’ve got a two camera edit (using multi-camera sequence). Is it possible to apply a color correction to one of the camera angles and have it apply to all instances of that angle on the timeline? If not after the edit, maybe earlier in the workflow?
    Mark
    Mark Hubert replied 13 years, 4 months ago 2 Members · 2 Replies
  • Kris Merkel
    May 17, 2013 at 2:46 pm
    HI Mark,
    I dont ever use the multi cam sequences but this is how it would be done.
    Create your multi-cam sequence and the select open in timeline and your sequence will open. Just select the layer you would like to add the CC to open in the source window and then drag the cc filter to the clip and CC away. Then run through and edit the sequence.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Mark Hubert
    May 18, 2013 at 2:39 am
    Thank you…. Love the elegance!!!!!
