Activity Forums Apple Final Cut Pro Legacy Video editing monitors
  • Video editing monitors
    Posted by Juha Västi on November 17, 2011 at 7:33 am
    Hey,
    I edit videos on my Final cut pro with basic samsung led monitor. The picture is good but it´s hard to calibrate it because there is no “Blue” only button. Can you recomend monitors that would be Broadcasting quality and inexpensive.
    Juha Västi replied 14 years, 10 months ago 4 Members · 4 Replies
  • James Clark
    November 17, 2011 at 12:00 pm
    Not sure broadacst monitors can be bought cheaply, especially if you need HD. Those things are pricey as far as I’ve seen, we have an SD one that we use just for colour grading, but as far high quality monitors go that are very good but not ‘broadcast monitors’ Eizo’s are good. They’re more expensive than a regular computer monitor, but still fairly cheap and cheaper still, than broadcast monitors. They have a large range of options so you can spend just under grand for their cheapest ones which are still pretty great or as much as 10 grand for their top of the range options.
  • Tony Brittan
    November 17, 2011 at 12:52 pm
    If you use te Matrox MXO2 (and others in the Matrox family), you can calibrate perfectly! They have a calibration system that you can use on any ol LCD (or other) HDTV and it uses standard HDMI.
  • Brad Wright
    November 17, 2011 at 2:52 pm
    I use a Panasonic Plasma THX certified monitor. It’s way more accurate than LED monitors. They are cheap too. There are certainly better monitors out there, but Plasmas have a color advantage over LEDs.
    Brad Wright is software engineer, so it may be difficult to understand what he is saying. He is always happy to explain his greater detail.
  • Juha Västi
    November 18, 2011 at 7:57 am
    Thank you very much for your tips. Maybe i try to cope with my Samsung for now. I read somewhere that you could use “blue gel” to andjust the monitor if you don´t have the blue only button but someone says that it does not work. “The accuracy of the blue gel trick is worse than setting the knobs to their middle position.”
    So what methods do you use to calibrate your monitors? would be nice to know. I thougt that in year 2000 it would be simple with one software but no =)
