Activity › Forums › Apple Final Cut Pro Legacy › Video Dropout
  • Alexander Lee
    September 3, 2007 at 9:35 pm
    [img]https://farm2.static.flickr.com/1044/1315815830_220c8f60dd_o.png[/img]
  • Michael Gissing
    September 3, 2007 at 10:44 pm
    If the dropout is just the one frame or field, then the repair plugins from CHV has a dropout fixer. Basically it lets you select a field from a previous or post frame and insert it in a defined area.
    I believe Digital Heaven have a similar dropout fixer plugin too.
  • Steve Cohen
    September 3, 2007 at 11:03 pm
    Or you can do the same thing manually.
    Select a clean frame from 1 or 2 frames before or after lay it on top of the bad frame and do a softedge crop around the bad video. then just reposition the good frame as needed.
    Steve
    Steve Cohen
    Editor
    O2 Media Inc.
  • David Roth weiss
    September 4, 2007 at 3:50 am
    [Michael G] “I believe Digital Heaven have a similar dropout fixer plugin too.”
    I use DH_Dropout from Digital Heaven. With it you can fix problems on just one field and it has soft edge controls as well as others that allow you to make perfect fixes.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Alexander Lee
    September 4, 2007 at 4:38 am
    You guys are awesome! Thx for the useful info… on Labor Day no less!
    Best,
    Alexander
