Activity › Forums › Adobe After Effects › Video Droplets in composition to import to Final Cut Pro
  • Video Droplets in composition to import to Final Cut Pro
    Posted by Alp Tekyildiz on March 24, 2011 at 6:11 pm
    Hi everyone
    A client had a request I’ve never had so far and I’m not quite sure if this is possible.
    The animation is a title sequence for a TV game show but there’s an element that will change at each “episode”. 2 videos will play on screen at different times, but these 2 videos (footage from that episode) will change every time.
    The client told me he knows that with Motion, you can create some kind of video droplets, which are frames for the video to go in. You can give motion to these frames and when you import the animation to Final Cut Pro, it recognizes the droplets and allows the editor to drop any video clip into the frames. This way the editor can change the content of the video clips without having to go back to Motion.
    I don’t use Motion and only, so I was wondering if there’s a way to do something similar with After Effects. It’s not acceptable for the client to have to contact me every week to add different video clips to the title sequence, so I really need to find a solution to this.
    Any suggestions ? Plugins are fine too.
    Kevin Camp replied 15 years, 6 months ago 2 Members · 3 Replies
  • Kevin Camp
    March 24, 2011 at 7:33 pm
    motion can be used to create ‘master templates’ that can have replaceable ‘drop zones’. and the drop zone elements can have animations and effects on them which will be applied to the footage dropped onto the drop zone.
    the master templates can be applied from fcp directly, where footage can be dropped onto the drop zones without having to open motion.
    you don’t have that kind of interactivity between fcp and ae.
    motion is pretty easy to learn and you can find a fair amount of info on the web on how to create master templates in motion (that’s how i learned how to create the few master templates that i’ve done). but you will need motion, and apple doesn’t sell it by itself anymore, only as part of the fcs…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Alp Tekyildiz
    March 25, 2011 at 9:05 am
    Thanks for the answers guys. That was quite detailed and just what I needed.
    Looks like I’m going to have to find a way to import AE projects into Motion. If you have other solutions, I’m all ears 🙂
  • Kevin Camp
    March 25, 2011 at 8:32 pm
    i don’t know of any way to import an ae project into motion (not that there isn’t away, i just haven’t done it).
    what i’ve done when creating master templates is to render out as much as i could from ae, export a couple stills to help line things up, and then recreate whatever couldn’t be rendered in motion, mainly the updatable elements.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
