Activity Forums Adobe After Effects Video distortion, warp.
  • Kalleheikki Kannisto
    August 16, 2015 at 4:17 pm
    You need to create a 3D elevation map from the grayscale image and use the same image as texture. Then add some lighting. How to achieve that automatically within After Effects for footage, no idea. If I were to do this, I would use Photoshop 3D, create an action and batch apply it to an image sequence. Not a very fast method, but you can leave it running the batch overnight.
  • Kasper Nyman
    August 16, 2015 at 6:09 pm
    So actually you will recommend using Cinema 4D for this?
    Either way thank you so much, a good help for google search for information.
    Nyman
  • Walter Soyka
    August 16, 2015 at 7:27 pm
    Check out Mettle FreeForm [link].
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
    August 17, 2015 at 7:30 pm
    On second thought, I would recommend Trapcode Mir, it can do what I describe (once you have your bad tv distortion footage created).
    Setting the Fractal frequency of Mir to 0 (and x and y scale to 0) you can use any image or footage to offset the surface in 3D. And you can map the same image/footage as texture on that surface.
