Activity Forums Adobe After Effects Video Distortion
  • Michael Duff
    December 5, 2007 at 11:06 pm
    it is a mix of different things … the vertical rolling is just animating the position and using hold keyframes …
    try using wavewarp…
    try using displacement map, and different textures as the map (like maybe use static as the map)
    add some static and noise over the top …
    Michael Duff –
    Bearcage Productions, Australia
  • Phillip Han
    December 6, 2007 at 3:51 am
    ty
  • Murforama
    December 6, 2007 at 9:42 pm
    There are plug-ins that could help you with this depending on your budget and how badly you need this look.
    https://www.toolfarm.com/plugins/index.php/The_Foundry_Tinderbox_3
    A bit pricey but the effect is probably easier created this way than by spending hours trying to manually shift elements.
    Murf
  • Stephen Davidson
    December 13, 2007 at 9:26 pm
    There is an excelent plug-in for this call Digieffects Delerium. Specifically the Video Malfunction one.
    https://www.digieffects.com/products/delirium.html
    Best Regards,
    Stephen P. Davidson
    http://www.3danimationmagic.com
  • Fabio Regano
    November 12, 2008 at 3:14 am
    I am currently using Adobe Premiere Pro 2 and have noticed significant artifacts or distortion during camera movement only. I originally filmed on digital DVcam tape and capturing from this source tape. When my source tape is played back through a domestic TV monitor no distortion appears. It only appears during capture and on the AVI file that’s produced. How may I overcome this problem?
    Many thanks!
