Activity Forums DaVinci Resolve Video dissolves when source media is flattened quicktime
  • Video dissolves when source media is flattened quicktime
    Posted by Jim Bachalo on August 6, 2013 at 1:20 am
    Haven’t been able to apply any cross dissolve effects in my project. Am using scene detection on a flattened quicktime.
    Will I need to go back into my NLE and export individually just those clips that need a cross dissolve?
    Local is the new global
    Josh Petok replied 13 years ago 3 Members · 4 Replies
  • Josh Petok
    August 6, 2013 at 4:14 am
    If you preconform you sequence with an EDL, all the dissolves will be in place.
    Josh Petok
    Online | Color
    JoshPetok.com
    TheCurrentCut.com
  • Margus Voll
    August 6, 2013 at 9:57 am
    I think he meant if he has one long file that is cut up by scene cut.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Jim Bachalo
    August 6, 2013 at 1:25 pm
    Yes to the above. Using scene detection. Instead of deleting my dissolves BEFORE exporting to flattened QuickTime, should I instead leave them in, and manually cut down the middle?
    I would then need to recreate them in Resolve.
    This has been suggested elsewhere but I thought it made more sense to delete the dissolves first.
  • Josh Petok
    August 6, 2013 at 1:45 pm
    Preconforming will take a flattened QuickTime (even with dissolves) and slice it up based on an EDL. However, since you’ve already graded it, that wouldn’t do you much good. I think recreating the dissolves in resolve is you best bet, but if it comes up again, I’d use the preconform workflow if possible.
    Josh Petok
    Online | Color
    JoshPetok.com
    TheCurrentCut.com
