Activity Forums Apple Final Cut Pro Legacy Video dimensions distorted on export.
  • David Roth weiss
    July 24, 2009 at 4:02 pm
    Don’t be blue Blue, it’s not your sequence settings that are the issue. Your problem is a setting inside QT Player. Check in Window>>Show Movie Properties>>Presentation — the highlight the title and check Conform aperture to “encoded pixels.” See if that does the trick…
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Michael Gissing
    July 25, 2009 at 7:42 am
    Standard def uses anamorphic squeeze to stuff a 16:9 image into the 4:3 frame size of SD. So what you are seeing in QT is that squeezed image. FCP is showing you the correct aspect but Qt isn’t.
    If you are exporting a QT for others to view, then you can adjust the scaling on export with QT conversion. I recommend downloading a cute little app called aspectRatio 1.8 which will convert anamorphic to normal depending on the SD pixels you are using (ie PAL/NTSC)
  • Shane Ross
    July 27, 2009 at 10:46 pm
    Your sequence settings are wrong. They show SQUARE and DV is not a square format. That should be set to NON-Square.
    Shane
  • David Roth weiss
    July 27, 2009 at 10:55 pm
    Good catch Shane, I didn’t even look at the pixel aspect ratio.
    David Roth Weiss
    Director/Editor
    Los Angeles
