Activity Forums VEGAS Pro Video desyncing when imported
  • Video desyncing when imported
    Posted by Dylan Evans on July 3, 2011 at 10:21 am
    Hi
    I’m editing a youtube video using Sony Vegas HD Platinum. When I try to import my footage it hugely desyncs the audio, and the audio begins to cut out periodically. The footage plays perfectly fine in quicktime, so I’m at a bit of a loss as to why importing it does this. I would just resync it, but that doesn’t solve the cutting out.
    Any help is much appreciated
    Whonut
    Dylan Evans replied 15 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    July 3, 2011 at 2:00 pm
    The codec used to deliver YouTube video is not a codec that you want to edit with. Use a tool like AviDemux to convert the video to a codec which edits easier. Try Motion-JPEG video with PCM audio. Here are the settings:
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dylan Evans
    July 3, 2011 at 3:09 pm
    Hi, I’m not entirely sure if you’ve understood my question. I’m not editing a video I’ve downloaded, I’m editing it to upload it. My camera shoots in mp4 (or mov, I think it changed when I put it on the computer). I don’t get the problem with my webcam’s footage, which I think shoots in AVI
  • John Rofrano
    July 3, 2011 at 4:39 pm
    You’re correct I misunderstood your question but the answer is still the same. Your camera obviously is recording in a format that is not good for editing. What camera is it?
    Since it’s a MOV file, you might want to use MPEG Slipstream to convert it to an AVI file using the Motion-JPEG codec with PCM audio. The bottom line is, whatever your camera is shooting, Vegas can’t use it as is so you need to convert it into something you can edit with.
    ~jr
  • Dylan Evans
    July 3, 2011 at 6:31 pm
    thanks, will do that.
    Also I forgot to thank you for your first reply :S Sorry about that
  • John Rofrano
    July 3, 2011 at 6:57 pm
    You’re welcome. Let us know what worked for you so that others can benefit from it in the future.
    ~jr
  • Dylan Evans
    July 13, 2011 at 6:46 pm
    I’ve tried to change codecs, few problems. One, there’s no PCM I can find with slipstream and two When I convert I get no video :S
  • Dylan Evans
    July 13, 2011 at 6:54 pm
    ignore my last post, problem solved (I was being an idiot). You were entirely right about the solution.
    Thanks so much
