  • Posted by Oliver Jones on March 6, 2009 at 8:07 pm
    After setting up FCP 6 on my new Mac Pro I have encountered a very annoying problem:
    there is slight delay between video and audio which makes accurate editing impossible. It says all is in synch but the video is delayed by at least a couple of frames. Played back a video outside FCP and it was fine.
    Can anyone solve this?
    Dino Vince replied 17 years, 6 months ago 3 Members · 3 Replies
  • Tom Meegan
    March 9, 2009 at 1:56 am
    You need to tweak your audio monitoring in:
    Final Cut Pro > System Settings…
    Then go to the Playback Control tab.
    Change the value in Frame Offset.
    Repeat until your monitoring is in sync.
    NOTE
    It is very important that you are sure that the footage you use to make this adjustment is in sync.
    The Frame Offset is only adjusting your monitoring to account for the different paths your audio and video are traveling on the way out of FCP.
    This adjustment could easily HIDE a problem with footage, or lead you to believe there is a sync problem with good footage IF you make your initial adjustment with footage that is not in sync.
    Best,
    Tom M
    Best,
    Tom Meegan
    Woven Pixels, LLC
  • Oliver Jones
    March 9, 2009 at 1:43 pm
    Thanks for the info. I’ll try that.
    An interesting fact I came across:
    When I convert my timeline setting to Quicktime H264 it’s in synch. I have always worked in DV PAL, so that seems to be a problem. I know my original footage is fine and in synch when I play it back OUTSIDE FCP.
    Any extra thoughts?
  • Dino Vince
    March 9, 2009 at 5:20 pm
    make sure all your settings match up, capture settings, sequence settings, etc. If it’s just a one time deal you can always unlock the video and audio by selecting the clip then using Command – L, then slip one or the other a couple of frames forward or backward till it’s synched. Good luck!
