Activity › Forums › Adobe Premiere Pro › Video Cropped
  • Video Cropped
    Posted by Joel Vanz on January 31, 2010 at 3:52 am
    I have imported an HD clip into Premiere and when I load it into my source monitor it looks fine but when I splice it into my timeline and look at it in my record monitor it is severly cropped or zoomed in. I do not want this because when I export, obviously it is cropped as well. Any help on this would be appreciated.
    Joel
    Jeff Pulera replied 16 years, 8 months ago 3 Members · 2 Replies
  • Vince Becquiot
    January 31, 2010 at 6:50 am
    Is your sequence set to the correct resolution. An example of that would be bringing 1080 footage in a 720 timeline.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Jeff Pulera
    January 31, 2010 at 3:57 pm
    If trying to use HD footage in an SD timeline, you need to right-click the clip on the timeline and select “Scale to Frame Size”. This can be set as a default in Preferences, then any clips imported after that will be automatically scaled.
    If you mean to be working in HD, then as Vince said, make sure Project settings match the footage
    Jeff Pulera
    Safe Harbor Computers
