Activity › Forums › Adobe After Effects › Video Copilot: Training for After Effects 7 < good for 6.5 also?
  • Video Copilot: Training for After Effects 7 < good for 6.5 also?
    Posted by Sean Barrett on April 19, 2006 at 5:31 pm
    Does anyone know if I would be at a serious disadvantage using 6.5 instead of 7 for the video copilot tutorial, After Effects 7: Serious Effects & Compositing? Thanks.
    Justin Productions replied 20 years, 5 months ago 4 Members · 5 Replies
  • Mylenium
    April 19, 2006 at 6:04 pm
    [Sean Barrett] “Does anyone know if I would be at a serious disadvantage using 6.5 instead of 7 for the video copilot tutorial, After Effects 7: Serious Effects & Compositing? Thanks.”
    I don’t think so. Judging from the promo, all techniques illustrated would work in AE 6.5, you may just have to accept some minor limitations and look a bit longer for some effects (as they are in different categories).
    Mylenium
    [Pour Myl
  • Andrew Kramer
    April 19, 2006 at 7:10 pm
    Well, remember it’s a Creative Cow Master Series Training DVD. They’re the one’s that helped make it happen. Big thanks to Kathlyn, Ron, & Aharon!
    Mylenium, you’re absolutely correct.
    Probably the only downside would be the finished project files aren’t backwards compatible, but you can import the footage into a 6.5 project and follow along just the same.
    But of course we suggest you upgrade when you can.
    I put some info on the site to clearify as well, so thanks for asking Sean.
    https://www.videocopilot.net/seriousfx.html
    Goes something like this:
    Can I use After Effects 6.5?
    So you haven’t yet upgraded to version 7? No problem. Serious Effects
    uses only the core tools of After Effects, so users can follow along
    with version 6.5 as well. Of course the overview of new features (01)
    won’t be available in 6.5, but you’ll certainly be prepared for the upgrade.
    Some parts of the interface may look different but virtually everything
    needed to follow along can be found in version 6.5.
    Project Files
    Although the project files can’t be opened in AE 6.5, you can
    still import the footage into a new project and follow along.
    Hope this helps,
    Andrew Kramer
    http://www.VideoCopilot.net
  • Justin Productions
    April 19, 2006 at 11:56 pm
    Hey Andrew, can’t wait for your Serious FX tutorials!
    And what about 6.0?! Will you use, in most of your tutorials, the Cycore effects?!
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
  • Andrew Kramer
    April 20, 2006 at 2:30 am
    I was curious so I launched all of the project files after removing the cycore effects from my plug-in folder and this is what I found:
    1. The muzzle fire tutorial uses “CC Fast Radial Blur”, but you can also use the standard radial blur but the cc just renders faster
    2. The DVD menu tutorial uses CC Vector Blur to make the fractal noise a little more organic but it’s mainly just adds texture and isn’t totally necessary. Also a pre-rendered version of just that element comes on the DVD since the fractal noise took too long to render I pre-rendered it by itself to be able to work faster.
    I don’t remember everything about version 6.0 does it have latest text presets or was 6.0 when it was first implemented. I just remember 6.5 being tons better than 6.0…
    Andrew
    April 22, 2006 at 3:06 am
    Nice, thx bud.
    Justin Productions
