Activity Forums Adobe After Effects Video Copilot solid alpha channel- Should be an easy one
  • Video Copilot solid alpha channel- Should be an easy one
    Posted by Emma Payne on February 13, 2014 at 10:16 pm
    Hey all! I’ve been using Video Copilot plugin for the first time and right away I’ve found an issue- It’s hiding up my footage behind it! I’m quite a newbie to AFX and I figure it’s an alpha channel issue. Can anyone tell me how to make my lens flare solid transparent so I can see the background but still have the lens flare showing?
    I hope that’s clear! Thank you all!
    Chris Evans replied 12 years, 6 months ago 4 Members · 3 Replies
  • Joseph W. bourke
    February 14, 2014 at 12:11 am
    Generally the best way to achieve the most realistic result is to put the layer with the flare on it in Add mode. It adds the value of the brighter pixels in the flare to the background layer, making for a better look than just making it keyable.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • John Cuevas
    February 14, 2014 at 4:02 am
    You need to change the Render mode from “On Black” to “On Transparent”.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Chris Evans
    February 14, 2014 at 3:12 pm
    If you watch the tutorials that come with the plug-in, it will explain things like this and a bunch of other important things. There are several ways to achieve what you are looking for, including what Joseph and John said, but Andrew Kramer actually recommends changing the transfer mode to screen instead of add because the lens flares were actually designed to be used that way and the falloff will look a little more natural. Of course, you should do whatever gets the best result, so play around with the different ways of doing it to get what you want.
