Activity Forums Apple Final Cut Pro Legacy Video Compression Modes for FCP from AE
  • Video Compression Modes for FCP from AE
    Posted by Howie Chin on June 23, 2006 at 2:17 pm
    I use AE quite often to create transitions to be used in FCP. Normally for alpha channels, i use Animation with Alpha.
    but for normal without transparency, i go DVCPRo in which my final ingest will be in. BUT, somehow, the quallity somehow
    drops. Is there anything that can be done to reduce the quality drop when i export from AE to be used in DVC Pro.
    I usually export to QT movie [ self contained] then to AE then export DVCPro to be back into FCP for further editing.
    thnx
    [howie]
    Wes Plate replied 20 years, 2 months ago 3 Members · 2 Replies
  • Lars Wikstrom
    June 23, 2006 at 10:39 pm
    If you do alot of this work then you might want to look into getting Microcosm. I use this to go between FCP and AE. It creates a file that is about 1/3 the size of animation codec and islossles that also handels 16 bit not just 8 bit like Animation codec.
    _lars
  • Wes Plate
    June 24, 2006 at 5:35 pm
    When you go from FCP to AE just use your actual media file, if you do that you don’t have to worry about recompressing or exporting or anything. If you only want to deal with a small section of media you can export a QuickTime Reference movie, again you won’t recompress so you’ll know you’re starting in AE from a good place.
    When you render, render to the codec that matches your FCP sequence preset. If you render to another codec, FCP will render the movie to your sequence preset for you. Animation is a good codec to use if you render with an alpha channel.
    — Wes Plate
    Automatic Duck
