Activity Forums Adobe After Effects Expressions Video clips flip onto the screen
  • Video clips flip onto the screen
    Posted by Joe Smoe on July 21, 2010 at 2:44 am
    I was wondering if there is an expression I could use to get the Fifth effect on the video on this site.
    https://finalcutprotemplates.com/templates/
    I basically want my video clip to flip onto the screen, and I know after effects can easily do this. I hope there could be an expression of some sort to solve this.
    Basically I’m hoping to flip a videoclip onto the screen by having it rotate on it’s X axis. I could easily do that with keyframes, but there must be an expression out there that give it more variables that I can even think of to make it more lively.
    Thanks.
    Chris Wright replied 16 years, 1 month ago 2 Members · 1 Reply
  • Chris Wright
    July 21, 2010 at 7:24 pm
    I can think of 2 ways off the top of my head.
    you can use Math.exp() to generate exponential curves. Say you have a slider (“Slider Control 2” in this example) with two keyframes, then you could calculate an exponential curve between the two values with something like this:
    slider = effect(“Slider Control 2”)(“Slider”) ;
    decay = 5.0;
    if (slider.numKeys < 2){
    slider.value
    }else{
    t = slider.key(1).time;
    v1 = slider.key(1).value;
    v2 = slider.key(2).value;
    if (time < t){
    slider.valueAtTime(time);
    }else{
    v2 + (v1-v2)/Math.exp(decay*(time-t));
    You would set the steepness of the curve with the variable “decay” (or tie it to a slider).
    //Or…
    Inertial Bounce is like making your moves “rubbery.” Layers will overextend, then settle into place on position and rotation keyframes.
    // Inertial Bounce (moves settle into place after bouncing around a little)
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n–;
    if (n == 0){
    t = 0;
    }else{
    t = time – key(n).time;
    if (n > 0){
    v = velocityAtTime(key(n).time – thisComp.frameDuration/10);
    amp = .05;
    freq = 4.0;
    decay = 2.0;
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{
    value;
    https://technicolorsoftware.hostzi.com/
