Activity › Forums › VEGAS Pro › Video clip stack order
  • Video clip stack order
    Posted by Tommieg on November 25, 2005 at 12:32 pm
    How can I change the stack order of videoclips on the same track?
    I have a long clip, and want to put shorter clips somwhere in the middle of the long.
    I know I can put it on a separate track, but I want it on the same track as the long clip.
    When I do this, the short clips sometimes come on top of the long one on the timeline, but sometimes it gets hidden under it. How can I control the stack order, and bring the short clip on top of the long?
    Tom
    Tommieg replied 20 years, 10 months ago 3 Members · 6 Replies
  • Peter Wright
    November 25, 2005 at 2:22 pm
    Use a higher track for the short clips, and they will take precedence.
    Vegas can have unlimited tracks, there is no need to confuse it by putting more than one clip in the same space on a track.
    If you must have it on the same track (why?) you can render to a new track from the two tracks already mentioned.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Tommieg
    November 25, 2005 at 2:37 pm
    Thanks, I’ll try that.
    >Vegas can have unlimited tracks, there is no need to confuse it by >putting more than one clip in the same space on a track.
    >If you must have it on the same track (why?) you can render to a new >track from the two tracks already mentioned.
    I’m editing a concert video, with lots of small clips from A LOT of different sources. It’s like playing with a puzzle. More clips are coming in continously, and I need to be able to remove clips (or part of clips) if better footage surfaces. I’s all synched to a separate audio source, and that’s why I prefer to have the clips on the same track. I tried to have clips from each source on it’s own track, but having 25 different sources (and counting) it really became a total mess.
    Now I put new clips on a new track and synch it to the audio source, then matches the new footage to the existing to find the best. If the new one is better, then I (cut &) move it to the main track. I don’t want to cut the existing footage on the main track, because I might change my mind later and want to switch back.
    Tom
    We’ll miss you Bestie….
  • Edward Troxel
    November 25, 2005 at 5:23 pm
    Is this a multi-cam shoot? If yes, you might want to look at scripts designed to simplify that process.
    Edward Troxel
    JETDV Scripts
  • Tommieg
    November 25, 2005 at 7:15 pm
    Yes it’s a multi-cam shoot (26 and counting), but none of the sources are complete, they are rather small clips. It’s like puzzle-game, trying to make the concert complete. I’m 75%-80% done, and I just wanna know if it’s possible to change the stacking order of clips on the same track.
    Tom
  • Peter Wright
    November 25, 2005 at 11:25 pm
    Tom,
    I agree you don’t want to start cutting the main track, but it would still be easier to add the shorter clips by using separate tracks above. You never need to put them on the same track – Vegas will render the whole lot into a single video when you’re finished.
    Here’s how I would proceed:
    I’d create several video and sudio track pairs above the main track. Not necessariy one for each other source, but enough to be able to see the separate components. The track immediately above the main track I’d reserve for “other” clips which are intended to be in the final programme.
    Here are some Vegas functions which will come in handy –
    In each track header there is a Mute button, so you can switch any track(s) off or on again during editing. This is useful when you want to view something on a lower track that would otherwise be lower in precedence than a track above.
    If you want to temporarily switch off a single event rather than the whole track, right click > Switches > Mute.
    Numerical 8 moves an event vertically up to the neat track, Numerical 2 moves an event downwards. When you’ve found a short clip you want to include and synched it up, you can use Numerical 2 to move it down to the “other” clip track above the main one.
    I would loosely arrange all the other clips in their approximate position, using as many tracks above as is necessary, then go through viewing, synching, deciding …
    Hope all that isn’t too confusing …
    Good luck – and yeah, George Best was the greatest. I was playing amateur football in England in the sixties and still remember how he dazzled us.
    Peter Wright
    Perth, Western Oz
  • Tommieg
    November 26, 2005 at 12:44 am
    I’ll try to follow that route!
    Tom
