Activity Forums Adobe Premiere Pro Video Clip plays audio in VLC, not in PPro — ??
  • Video Clip plays audio in VLC, not in PPro — ??
    Posted by Eric Chard on July 27, 2022 at 5:00 am
    I have a number of *.MOV files that will play in VLC, both audio and video, but not in PPro. So the audio is there, and the freeware can play it, but the commercial s/w does not.
    Acting on a suggestion, I used MediaInfo to examine the file, but… not sure what to do with the info. Here’s the TEXT output from MediaInfo, thanks for any help:
    General
    Complete name : D:\Gigs & Projects\SonicBench2010\Footage\2009-Capture\SonicB_002.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2005.03 (qt )
    File size : 16.6 MiB
    Duration : 6 s 473 ms
    Overall bit rate mode : Variable
    Overall bit rate : 21.5 Mb/s
    Encoded date : UTC 2009-12-30 04:14:52
    Tagged date : UTC 2009-12-30 04:15:03
    Writing library : Apple QuickTime
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L3
    Format settings : BVOP
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : mp4v-20
    Bit rate mode : Variable
    Bit rate : 21.5 Mb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Original display aspect ratio : 3:2
    Frame rate mode : Constant
    Frame rate : 29.970 (29970/1000) FPS
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 2.075
    Stream size : 16.6 MiB (100%)
    Language : English
    Transfer characteristics : BT.601
    Matrix coefficients : BT.601
    Audio
    Format : Qdesign 2
    Codec ID : QDM2
    Codec ID/Info : QDesign Music 2
    Source duration : 7 s 552 ms
    Bit rate mode : Constant
    Bit rate : 256 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 32.0 kHz
    Stream size : 202 KiB (1%)
    Source stream size : 236 KiB (1%)
    Language : English
    Sally Asaku replied 4 years ago 3 Members · 4 Replies
  • Tod Hopkins
    July 27, 2022 at 12:44 pm
    Likely the deprecated QT MPEG4 codec. I’m assuming you are on a Mac. PP simply doesn’t play everything. VLC does (almost). You’ll need to convert. Since VLC can play it, you can probably convert with anything that uses FFMPEG for core conversion. You can convert with VLC but it’s a PITA. Presuming you want to convert to a pro format, like ProRes, I suggest FFWorks. In short, it’s a matter of finding an app that can read the file and convert to the format you want. Worst case, you’ll need Windows, Linux, or an old Mac (pre-deprecation) but chances are FFMPEG can handle it.
  • Eric Chard
    July 29, 2022 at 9:07 pm
    Thanks for your reply. I am >not< on a mac.
    I believe “Shutter Encoder” will do the job: I tried to save from VLC, but the resulting file did not have the audio (which VLC will play from the original) attached. >:^(
  • Tod Hopkins
    July 29, 2022 at 10:17 pm
    If Shutter Encoder does work, try handbrake set to Production preset.
  • Sally Asaku
    August 15, 2022 at 9:22 pm
    FFmpeg supports DM2 and QDMC, so you should be able to convert the music to a more common format such as AAC with the build-in conversion of VLC (VLC is FFmpeg-based).
