Activity Forums Apple Motion Video Cards Question
  • Video Cards Question
    Posted by Tobin Nageotte on May 3, 2006 at 10:15 pm
    I have a G5 1.8DP with 3G RAM and I’m looking to upgrade my video card for use with After Effects and Motion. I’ve scrolled through previous posts on the subject, researched the test sites, etc. I’ve narrowed it down to three options:
    – Nvidia 6800
    – ATI X800
    – Radeon 9800
    The 6800 and X800 seem comprable, but the price for the X800 is somewhat less. I’m looking at the 9800 b/c of the S-VHS out. I run a monitor through a camera right now, but I’d like to find another solution. Unfortunately, I can’t spring for a deck or an AJA device.
    Any advice? I work primarily with DV, but, lately, HD has grown into the picture. I wish I had all the money in the world, but I’m looking for a solution that will maximize my compositing speed at a reasonable price.
    Apologies for the vague explanation. Hopefully, someone will have experience with my situation.
    Best,
    Tobin
    Anne Pascal replied 20 years, 4 months ago 8 Members · 9 Replies
  • 9 Replies
  • Jim Kanter
    May 3, 2006 at 10:30 pm
    x800 is the best value if you don’t intend to run a 30″ Cinema Display. Also, ATI was offering a $50 rebate to North American users who upgrade to an x800 and turn in their old video card.
    If you want to get a 30″ CD then get the nVidia.
    If you’re planning on using Motion a lot, stay away from the Radeon 9800–not enough horsepower.
    You should also look into a firewire DV to analog converter box to run the monitor.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Walter Biscardi
    May 3, 2006 at 10:31 pm
    [thirtysevenclick] “I’m looking at the 9800 b/c of the S-VHS out. I run a monitor through a camera right now, but I’d like to find another solution. Unfortunately, I can’t spring for a deck or an AJA device.”
    You can’t run full quality video through the 9800 to a video monitor and use that for your NTSC monitoring. You need a video card or an AJA Io type of device.
    If you’re looking for very fast performance on the Mac with Motion, look at the ATI x800XT if it fits into your Mac. Faster than the x800 and doesn’t take up two slots like the nVidia 6800. I run both the 6800 and the x800XT here and speeds are basically identical.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Doyle Rockwell
    May 3, 2006 at 11:14 pm
    Heya,
    All other things being equal, don’t forget that ATI cards are limited to 2048×2048, so larger images can get cropped. Nvidia cards allow for 4096×4096, which gives you more breathing room.
    And believe me, it’s easy to hit that 2K limit on even standard def work.
    Good luck with your purchase!
  • Winston Cely
    May 8, 2006 at 11:58 pm
    So I just got an X800XT to replace the 9800 Pro. I see very little difference. Maybe I’m expecting too much? I’ve got 2 20″ displays both running at 1680×1050. Plus, 4.5 Gigs of RAM under the hood (which we’ll be maxing out to 8 gigs in the coming months). I think the one thing I do notice is that if I run the flurry screensaver, I don’t see the screen being painted as much.
  • Mark Spencer
    May 11, 2006 at 1:38 pm
    Running two displays with Motion splits the VRAM on the graphics card in half and impacts performance – try disabling one of the displays.
    Mark Spencer
    Freelance Editor/Producer
    Apple-certified instructor, FCP, DVDSP and Motion
    Author, Motion Visual Quickstart Guide from Peachpit Press
    https://www.applemotion.net
  • Brian Pitt
    May 11, 2006 at 8:05 pm
    I guess that Explains why Motion runs quite slow on my machine, even though I have the x800xt. I am running 2 24″ Dell LCDs. I’m going to try disabling one of them. Is there an easy way to do this without climbing under my desk and unplugging one?
  • Winston Cely
    May 12, 2006 at 1:02 am
    I had tried that with the last card, and didn’t see any change. I am, however, going to try that again this weekend. Would lowering my monitors resolution have any noticeable effect on performance?
  • Mark Spencer
    May 14, 2006 at 2:46 pm
    Unplugging the monitor won’t stop the VRAM split – you need to disable it with the card’s interface, usually available in system prefs.
    Mark Spencer
  • Anne Pascal
    May 25, 2006 at 1:11 pm
    Dear Tobin,
    I am about to buy a X800XT to replace a 9600 (64MB):I have one new 20 inch display and one old ADC as the 2nd display.So from you experience, does it make Motion 2 go quicker in realtime playback or not???
    Anne
