Activity › Forums › Apple Motion › video card and Motion3
  • video card and Motion3
    Posted by Kim Rowley on January 11, 2008 at 12:07 pm
    I’m about to be between editing jobs and am finally ready to upgrade to FCP Studio2 with Motion3. My video card – ATI Radeon 9650 – I realize is at the lowest end of the system specs. I do not do a ton of graphics or plan on heavy duty 3D in the near future. If I do simple slates, lower thirds, some simple animation or graphics using pre built templates am I still setting myself up for a rough ride? I have 4GB’s of RAM.
    Thanks for anyone’s experience or advice.
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.1.2, OS X10.4.8
    Kim Rowley replied 18 years, 8 months ago 2 Members · 2 Replies
  • Gabriele De simone
    January 16, 2008 at 7:37 pm
    The ATI Radeon 9650 isn’t fast by today’s standards, but if I’m not mistaken it comes with 256MB of VRAM and that should let you work with HD-sized frames at 8-bit fairly well.
    If you’re planning to use built-in or third-party plug-ins based on FxPlug, keep in mind that you may get an error message that says “failed to render at the current size, etc…” when working with HD-sized frames.
    If that ever happens, switch your Sequence Settings > Video Processing option to “Render in 8-bit YUV” and you should be able to render fine.
    AFAIK, the only Sequence presets that comes with high-precision rendering enabled by default are the (new) ProRes presets.
    Hope this helps,
    Gabe
    Noise Industries, LLC
    https://www.noiseindustries.com
  • Kim Rowley
    January 17, 2008 at 8:56 am
    Thanks for the heads up Gabe.
    So far everything is working fine but I’ll keep that in mind. I know that was already the case for my Sugar plug-ins.
    Cheers, kim
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP Studio 2 (6.02), OS X10.4.11
