Activity Forums Apple Final Cut Pro Legacy Video capture/playback settings
  • Video capture/playback settings
    Posted by Joey Groah on November 19, 2005 at 4:59 pm
    Hi ladies and gents,
    Here’s the set up:
    – just upgraded to Final Cut 5 via HD Studio upgrade
    – our deck with the Firewire in is the JVC SR-VS30U combo deck
    – video source in has been mini DV and DVD
    The video is “jerky,” almost looking like there’s an interlace problem, like there are dropped frames, though there’s no error message. The audio is fine.
    I’ve gone through the preferences I know to check, and everything looks right to me. I feel like this is going to be one of those “head slapping ‘Duh'” moments, and I’d greatly appreciate any thoughts.
    Joey
    joey@GoDigico.com
    https://www.GoDigico.com
    Enzo Tedeschi replied 20 years, 10 months ago 3 Members · 4 Replies
  • Tom Wolsky
    November 19, 2005 at 6:16 pm
    Where is it jerky? During capture? After capture playing back in the Viewer? On an external video monitor? If it’s during playback, is the log and capture window closed? Are the Viewer and Canvas set to Fit to Window?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Joey Groah
    November 20, 2005 at 2:40 pm
    “Where is it jerky? During capture? After capture playing back in the Viewer? On an external video monitor? If it’s during playback, is the log and capture window closed? Are the Viewer and Canvas set to Fit to Window?”
    Hi Tom,
    Video is “jerky” after capture, during playback in the viewer and an external monitor. Log and capture are close, viewer and canvas are set to fit the window.
    We’re also seeing some motion blurring on video of objects in motion. For example, on a piece of video captured before the upgrade, there’s a shot of bus with feet getting on the bus as the bus door opens. The feet and the swinging doors have some “jaggedness” while the background looks fine.
    Thanks for your response,
    Joey
  • Tom Wolsky
    November 20, 2005 at 2:58 pm
    Are you getting dropped frame warnings?
    The jaggedness sounds like you’re seeing interlacing during playback. You shouldn’t see this on your video monitor.
    All the best,
    Tom
  • Enzo Tedeschi
    November 20, 2005 at 8:46 pm
    Tough one without seeing… jagged edges is usually an interlacing problem, though. Tom is right.
    Maybe check a couple of things if you haven’t already re: jerky playback:
    Clip settings – was the footage OK before the upgrade?
    Sequence settings – these should match your clips
    RT Settings – the wrong RT setting on your machine could cause weird playback
    Hard Drive – how full is it? You may get dropped frames if your drive is really fragmented or full, etc. Is it a separate media drive?
    And definitely check your stuff on a video monitor, not your computer screen, to look for those jagged lines as Tom suggested.
    Good luck! Hope this helps.
    e.
